Old 04-06-2010, 11:00 AM   #180 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
Quick checks to see if the connections look right.
on the custom screen:
start the engine, you should see the gh (Gallons per hour) reading go up, more gas pedal should give larger gh . If so the injector connection is probably ok.
Drive, the S number should be proportional to vehicle speed, if so then your vss connection is probably working.
