Old 04-07-2010, 01:41 AM   #7 (permalink)
mcrews
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
I like very much what you've done and I certainly don't want to discourage your efforts,but I wanted to point out that Nissan has done enough under car aerodynamic refinement on the Infiniti that they've published advertisements showing only the underside of the car.
Bottom line ( no pun ) is that you may not see gains,as say,you'd see on a Jeep,Land Cruiser,Rover,Tahoe,Suburban,etc..
Your refinements will put you in good stead for tail modifications should you choose to pursue that in the future.Nice work!
Actually, you are right a STOCK Q45 has some nice underbody panels that seal right up to the FACTORY bumper......
however, my situation is a little different.
I am running a Full IMPUL body kit which lowers the body lines 2 inches all the way around...
creating this.....
here was my dec thread describing my results....along with a blocked grille.
http://ecomodder.com/forum/showthrea...q45-11402.html
