Old 04-07-2010, 12:53 PM   #12 (permalink)
Piwoslaw
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Orzeszek - '18 Škoda Citigo Ambition
These may be of interest:
How much current does the A/C compressor draw? - GreenHybrid
Prius Air Conditioning System [PDF]
Electric Inverter A/C System for TOYOTA PRIUS Hybrid Vehicle [PDF]
The third link shows that the Prius' electric A/C compressor uses 19% less fuel compared to the engine driven compressor of an older Prius version.
Since the Prius' A/C system uses higher voltage, the compressor itself is 40% smaller and 53% lighter than a conventional electrically driven compressor.
The Prius' system is electric to allow the use of A/C while in stealth (engine off) mode, so I wonder if this will be adopted in more cars as gas-saving engine start-stop systems become more popular? I guess that the major obstacle is the power needed. Running the A/C @ max at a 90-second red light may drain your battery enough to leave you stranded. High voltage systems, where are you?
