Old 04-08-2010, 02:00 AM   #200 (permalink)
Otto
Originally Posted by ECONORAM View Post
I think this is a good idea. The cheapest 21" pizza pans I could find were $15 each, the ones I thought would fit are $30. I have 20" alloys on the truck.
I am looking at this, using some 1/8" plexiglass. Plexiglass,acrylic sheet,custom cut to size This place will cut a 20"x20" for $13, and I found some plastic 20"x39" containers at Bed, Bath and Beyond that are only $15 each. I could get all 4 covers from that! Just gotta figure out how to fasten them to the wheels WITHOUT damage. Any ideas?
You might want to consider PETG clear plastic rather than acrylic Plexiglass. Much tougher, PETG is the stuff used to make water bottles, etc., and probably cheaper, too.
Make a circular template the exact size needed to fit your wheels, cut out the hole, and use as a pattern for PETG sheet clamped on. Put in oven, plastic will heat and sag to slightly convex shape, stiffer and more aero than a simple flat disk.
Got good attach to wheel method yet?
A set of clear disks over stock alu cast wheels would look good, go on for highway trips but come off easily to air the tires, etc..
