Old 04-08-2010, 05:47 PM   #10 (permalink)
lunarhighway
vectra a - '95 Opel Vectra GLS
90 day: 37.51 mpg (US)
what you have to remember is that the grill is there for a reason, so adding a little opening is no sin, you could have a little manual shutter for these occasions or leave a small opening all the time... this could actually be enough to allow the fan to controle the situation, and if this situation don't occur very often, the fan is a good and safe solution.
i only tend to build up heat when stuck in stop go traffic and barely moving, as soon as i pick up a little speed the small hole i left is enough to bring things down to normal levels.
also if you overheat at low speeds where the ram effect trough the grill is small, so a hole anywhere (ie the bottom in front the the rad) where the fan can collect fresh air might work.
aer·o·dy·nam·ics: the science of passing gass
*i can coast for miles and miles and miles*
