After I am happy with my power section, I will move onto the logic
We work the same way on that point.
Are you just throwing things on a protoboard and then come up with a schematic? I couldn't do it that way - I'd forget half the stuff if I tried. Have you given thought to using an off the shelf driver? Those can be expensive sometimes but not when compared to a high power IGBT. Most drivers have things like shoot-thru prevention, boost pumps and inverters which make life easier.
Good luck with your lab work!
JR
