Old 04-08-2010, 10:00 PM   #237 (permalink)
TheSGC
Originally Posted by JRoque View Post
We work the same way on that point.
Are you just throwing things on a protoboard and then come up with a schematic? I couldn't do it that way - I'd forget half the stuff if I tried. Have you given thought to using an off the shelf driver? Those can be expensive sometimes but not when compared to a high power IGBT. Most drivers have things like shoot-thru prevention, boost pumps and inverters which make life easier.
Good luck with your lab work!
JR
I have been working on a schematic because most prebuilt IGBT drivers do not work with the large IGBT modules. I have actually designed a driver a few years ago that worked with a single large IGBT module, but I have modified the design to function with a dual IGBT module. I can't actually try out the dual setup until I get two isolated DC/DC converters.
Civic EV http://2001-civic-ev.blogspot.com/
Solectria Force http://solectriaforce.blogspot.com/
