Originally Posted by MARTINSR
I have a 4 mile to work commute down a city street with a 45 mph speed limit and about 20 lights.
That is NOT a "city street". You are fortunate to be driving on a main suburban road with a speed limit that is relatively high.
City streets have a stop sign on every other block, if not at every block. City streets have a maximum speed limit of 30 MPH (if not lower). City streets have slow-poke drivers that have nowhere in particular to go except shopping, going for a car ride to get out of the apartment, mommies who drive while screaming at their kids in the back seat, and senior citizens who are either arguing with each other, or driving while comatose. City driving requires tremendous patience. If you've ever lived in or near a large city with the challenges of
real city driving, you'd understand what I mean.
Every once in a while I will hit a majority of the lights, I have actually hit every single one of them a time or two. But never seem to pull it off the next day, it is more about luck than my skills aparently.
What tips do you guys have on pulling pulling off hitting your signals while green?
There are only two things that determine whether the light stays green in your direction: timed traffic lights (that occur in suburbia on main roads) that are timed in one direction ; i.e. if you live near a sizable 'city' and traffic flow is mostly going in or out according to 'rush hour' or the time of day. The other factor is cross-road traffic that triggers the light so they can enter.
You can observe the first situation and try to avoid a particular road when the lights are timed against you (favoring the flow of traffic in the opposite direction). But you can do virtually nothing about cross triggered traffic except to speed up to make the light - or, see that it will change and slow down because you can't proceed - or, STOP if necessary.
Realistically, there is only so much you can do...
