...an analogy: sucking air thru a straw doesn't get any better when you put a propellor at the other end of that straw.
...however, a turbo *will* let you *use* all the octane value of ethanol-laced fuels (E85, etc.) although you might have to "double-gasket" the engine heads to drop the static compression.
