Old 04-10-2010, 05:21 AM   #8 (permalink)
fatman57
ye - i am aware fo the smaller engine turbo thing and the miller cycle (which I was also looking into).
I would use it on a four cylinder inline, maybe a 1.6 or a 1.8.
The big thing i need some feedback on is the cam setup - do you think it will work?
A big issue is the idle..........by my laymans logic the pistons will still be sucking in air on the downstroke and since so little goes in for idle the turbo could simply add a little if needed but i doubt it will need to do much for idle, mostly for getting it going........
