Old 04-10-2010, 10:05 AM   #11 (permalink)
mechman600
mechman600's Avatar
Fusion - '16 Ford Fusion Hybrid SE
Originally Posted by fatman57 View Post
A big issue is the idle..........by my laymans logic the pistons will still be sucking in air on the downstroke and since so little goes in for idle the turbo could simply add a little if needed but i doubt it will need to do much for idle, mostly for getting it going........
A turbocharger does not have the capability of doing anything at idle. It requires increased engine load, which increases exhaust flow to spool it up, hence the reason for turbo lag. You would not be able to rely on a turbo for what you want to accomplish. Like I said earlier, a mechanically driven supercharger would be the answer, but they have efficiency problems, which would most likely negate your entire efforts.
