I think the rule of thumb is that gearing changes are marginalized without a corresponding aerodynamic change, it moves you left (rpm) on the bsfc chart, but since the power requirements are basically the same it moves you up the load axis. So if you happened to be southeast of the bsfc sweet spot then you might get lucky, but generally it doesn't work like that.
