Old 04-14-2010, 10:37 AM   #1 (permalink)
NeilBlanchard
Accessing front turn signals on Scion xA?
Hello,
I am trying to change out the front turn signal bulbs on my Scion xA -- they are tucked up into a tight niche, that has several sharp metal edges. The socket needs to be turned and pulled out, and I cannot get to it well enough with my fingers. There are two large Phillips screws visible that are holding the whole headlight unit in place -- but I removed the screws and the headlight unit still doesn't move.
Any ideas of how I can replace the turn signal bulbs?
