Here is a link to the codes:
OBD-II Check Engine Light Trouble Codes
Looks like you may have to change the canister... Check up under the gas tank- near the rear passenger side wheel well. You may be able to see the canister wedged in towards the front of the car. You may be able to unstick the valves with a couple of tanks of gas with some solvent in it, (Xylene, Acetone, Chevron w/Techron) but more than likely you will be heaving that part out the window and replacing it. That is one of the biggest complaints of this generation of Corolla. Clear the codes and hope for the best.
To get when your's was manufactured, look on the inside door jam of the driver's side front door, just below the latch. It was most likely Canada. To figure out the engine info, check on the underside of the hood for the hood sticker, or under the hood on the front frame components. I can't remember for sure. But if you have the 1ZZFE, you have a VVTi engine and that will improve your mileage and pickup. Let us know how it turns out.
