Old 04-14-2010, 08:21 PM   #14 (permalink)
moonmonkey
ecomonkey
silver clown - '02 toyota echo 2 door base
90 day: 47.16 mpg (US)
white ghost - '05 prius base
90 day: 47.53 mpg (US)
white pearl - '12 toyota prius base
Last 3: 45.69 mpg (US)
for the summer you can use 100% water and water wetter, i used it on a f-150 where i had a bad overheating problem when pulling an over sized travel trailer, if i ran the heater at full fan speed it would stay just below boil over, that was with straight water, with water antifreeze mix it boiled over, with water and water wetter it dropped my temps an extr 6 degrees f allowing me to pull without running the heater,,, not fun in the florida summer. just remember to switch back to antifreeze water mix for winter freezes.
