Old 04-14-2010, 11:21 PM   #53 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
What is the tach drive signal for the Suzuki cluster? I'd imagine it's a single wire, usually the ground from the coil. If that's the case, it should work just fine w/ the G10, with similar modding as the 4 cyl Suzuki cluster requires.
Just sayin'.
