Old 04-15-2010, 11:42 AM   #2 (permalink)
IsaacCarlson
eco....something or other
wood hauler - '91 Ford F-250
Team Pontiac
90 day: 26.69 mpg (US)
Rav - '06 Toyota Rav4 Base
90 day: 26.52 mpg (US)
dang...get a low-end cam. That can give you a little more torque on the bottom end. It might be enough to let you use 5th at 35mph. You could also pick up a small industrial turbodiesel and put it in there. Those things make some torque!! I have been looking at some for my pickup and even at full load running against the governor, they only use 1-2 gal per hour. And we don't need to run them at full load and full rev going down the road. I did the math and I gould get 50+ mpg with a small industrial turbodiesel. The reason I saw industrial is because they are more efficient and are designed to WORK all day on a tank of fuel. My dad burns about 1.5 gal/hr in his bobcat.
1991 F-250:
4.9L, Mazda 5 speed, 4.10 10.25" rear
