Old 04-15-2010, 02:22 PM   #54 (permalink)
Gasoline Fumes
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
Luckily most Japanese cars use Nippon Denso or Nippon Seiki gauge clusters. They are for the most part, electronically interchangeable between Japanese cars. Convert the CRX tachometer to work with a 3-cyl engine and the Honda cluster should work fine with the Suzuki engine. The gauge side of the speedometer cables should be the same, so use the Suzuki cable if it's long enough. I'm not sure if the transmission ends are the same or not. Both Honda and Suzuki speedometers should be 1026 revolutions per mile. The Suzuki (Denso) ECU will expect to see a VSS signal from the speedometer, but I thought all PGM-FI Hondas had the VSS. I know disconnecting the cable on a 1991 Civic Wagon results in a check engine light. But if the cluster really doesn't have the VSS, you should be able to take the cluster apart and add one.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
