Old 04-15-2010, 04:16 PM   #17 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
lol, well psi is psi, and area is area, and since it is measured values the egr doesn't mean anything for these calculations. so you are looking at maybe 20hp in a 13L (large swag), that is to say if you reversed the pressures and put 50psi on the inlet and 40 on the outlet (or any 10psi differential) you could expect 20hp on the shaft then subtract for losses (VE/friction). Pretty far from zero meaning though.
I'm merely trying to point out that backpressure is a very real consideration, not something to be ostracised to the land of magic.
