Well, bud, you can keep believing that, but I've actually seen engines ingest oil when the crankcase was severely overfilled. A quart high, not a chance, but when the oil change specialists at Meineke decide to drain the transmission and refill the engine during an oil change, and now there's nearly 12 qts of oil in the engine, well, that's going to cause a problem.
