Old 04-17-2010, 12:05 AM   #59 (permalink)
ojman873
ojman873's Avatar
Accent1 - '07 Hyundai Accent GLS
90 day: 28.88 mpg (US)
Send a message via AIM to ojman873
In lieu of having an actual BSFC map for one's particular engine, would the Gallons/hour setting on the scangauge be a fairly good indication of how efficient your speed is?
Usually when I'm cruising on the interstate, the GPH readout is between 1.4 and 1.8 GPH; but it also reads similar number quite often at lower speeds, like suburban streets at 45 mph...
