Old 04-18-2010, 06:44 AM   #3329 (permalink)
jackbauer
jackbauer's Avatar
Did a few quick mods to the "bauer-con" this morning. Changed C20 and C21 to 16uf 35v tantalum and added a 1uf 1000v mkp snubber across M- and B-. No more ripple on the gate drive. I did buy a 15v dc dc with the intention of replacing the 12v unit but the pcb didnt want to let it go! The only way i could remove the 12v would be to cut it up with a snips and pull out the pins one at a time. Not something i want to do to a 40 euro part just yet
ludiagsm , as far as i know the lexus inverter runs at 650vdc.
ID:	5956   Click image for larger version
ID:	5957   Click image for larger version
ID:	5958   Click image for larger version
ID:	5959   Click image for larger version
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
