Inside wheel covers ?
Has anyone done wheelcovers "inside" the wheel ? Covers could rotate with the wheel, like with normal covers or the covers could be mounted with brake saddle. In some cases a big brake disk is some kind of "inside wheelcover". Any ideas ? It is quite obvious that inside covers would effect less than outside ones but how much less? Is there some disadvantage ? Control arms need some space so you can't never do full cover or can it be done at all ?
