Old 04-19-2010, 01:52 AM   #18 (permalink)
bgd73
oldscoob - '87 subaru wagon gl/dr
90 day: 47.06 mpg (US)
Originally Posted by IsaacCarlson View Post
dang...get a low-end cam. That can give you a little more torque on the bottom end. It might be enough to let you use 5th at 35mph. You could also pick up a small industrial turbodiesel and put it in there. Those things make some torque!! I have been looking at some for my pickup and even at full load running against the governor, they only use 1-2 gal per hour. And we don't need to run them at full load and full rev going down the road. I did the math and I gould get 50+ mpg with a small industrial turbodiesel. The reason I saw industrial is because they are more efficient and are designed to WORK all day on a tank of fuel. My dad burns about 1.5 gal/hr in his bobcat.
that is a cool thought..
I saw a ford fiests with a 2cyl turbo diesel at a hot rod forum (yes an oxymoron) clever...
if the car can take the torque, minimal throttle, and vibration that is the winning gear. it is very simple.
the little boxers are famous for this.. I take it to 1200 on a hill, let it rumble.
the diesels could do better, but as the cam wasmentioned, today they try to keep them higher strung like everything else wobbling.
