Originally Posted by mhmitszach
I realized what it meant. Overdrive is just the highest gear. There is no way to turn it on or off. Which sucks, because at about 43 mph it shifts to the highest gear.
I might try shifting into neutral again.
There should be a way to disable overdrive. Either in the shifter pattern or a lockout button/switch that is on or near the shifter. If the shifter pattern is P R N (D) D L, then "D" is regular drive, without overdrive. If it goes (D) 3 2 1, then "3" is what you want.
Jandree22, my 20 year old car has fuel cut on decel, so I would hope his car of half that age would have that feature too.
