Originally Posted by Otto
The problem is to remove it, not to anchor it: That stuff sticks to everything it touches.
Probably best to use a separating barrier that the Great Stuff will not stick to, like Saran Wrap of plastic that will conform to the shape of the car, and make a base. Then, built up and sculpt the base into boat shape.
You could use some aluminum screen in the Great Stuff, to make an internal hard point for attaching to the car.
mmm...and, if, I make stamp matrix whith cardboard and I fill it whit the foam spay?.
After, I could apply it fiberglass ?
For anchor, I could make necessary hole in the rear bumper, wath you say?
