Old 04-20-2010, 09:17 AM   #9 (permalink)
Ryland
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
Originally Posted by luvit View Post
when recycling, you don't want this stuff to leak out in your car. that would be bad. dump the battery's liquids out in the front yard.
Why not just dig a hole and drop the whole battery in?
When you recycle lead acid batteries they recycle the lead, the acid, the plastic, pretty much every part of the battery is recycled other then the dirt that's on the outside, that is why when they pay you for them they pay you for the wet weight of the battery, the recycling place wants the full!
Worried about leaking? then don't tip them over, large batteries do just fine under the hood of a car for years at a time, motorcycle batteries are on their side when the bike is on it's side, so unless the battery is busted open you should be fine, it is still a good idea to place the battery on a piece of card board to keep the floor of your trunk clean and if you do have a cracked battery then put baking soda on any spills, you can also dust your hands and cloths with baking soda if you spill on your self or rinse with water, the acid will not eat your skin instantly but if you don't wash it off it can give you mild chemical burns or a dry, chapped skin feeling.
