Old 04-20-2010, 02:59 PM   #4 (permalink)
Red Lion
Serenity - '93 Nissan Sentra SE-R
90 day: 20.55 mpg (US)
Originally Posted by AeroModder View Post
Awesome! but did you remember to check where the needle was on your gauge the last time you filled it, and compensate for the difference after the next fill? The pumps never "click" at the same amount, so if you don't correct for that, it'll either inflate or deflate your numbers. Over a long-term fuel log, you'll get an accurate average by writing down exactly how much was added, but for a single tank, you have to compensate for the amount of fuel between "clicks."
Also, with such a low amount of fuel, it's extremely hard to get an accurate MPG measurement. Just an extra 0.32 gallons to make 1.5 drops it down to 41.6 mpg.
It was at the very top of the "E", as it usually is. I'm anal and make sure I fill it the exact same way each time. I do three clicks: the first, fast fill until it clicks, then I ease on the handle and let it flow slow until it clicks again, then one last easy, slow flow for the last click. It doesn't overflow, and always comes out at the very top of the "E".
But I get what you're saying though. I'll be taking a trip in a month where I'll be able to better see what type of MPG I get. I hope it's close to this good if not better!
Originally Posted by Dave's Civic Duty View Post
Great job on the MPG's!
Thanks!
