Old 04-21-2010, 02:42 PM   #3350 (permalink)
dave koller
dave koller's Avatar
Originally Posted by Tweety View Post
That plus the precharge resistor tends to build heat as it's a bit owerwhealmed by the current... So leaving it connected might not be a good thing long term...
In my humble opinion, once the caps reach pack voltage - there is no current drawn through the pre-charge... and keeping the value (resistive) high should not overheat it much in the initial stage of pre-charge - just take a bit longer..
I wondered if cl-30 inrush thermistors would be a good,fast, pre-charge alternative.. I use them to cushion the inrush to the DC/DC - any thoughts?
Dave ...
