Old 04-22-2010, 04:21 PM   #16 (permalink)
Raphael Travethen
Cool
I believe the best way to shiled you tire is not a tool install on the outside, but instead on the inside of your wheels. For protection of wheels and tires the best way is definitely the FLATS OVER System. It is made of rubber so it does not transfer impact from the contact of the floor to the wheels in case of bumps and flat tires.
It is also efficient against fire arms. I saw it on a test in Italy and got very impressed. They drove something like 100Km with a flat tire, than shot the tire, then the tire came off after some 50Km flat and shot at and still the car maintained perfect driving conditions. I just got one for my car and some for my company’s cars as well. Easy to install and uninstall to transfer to other wheel of the same size. Any mechanics can do it following the manual. Highly recommended. I found them at Google at first.
It might sort your problem with no difference in your car appearance.
