Old 04-22-2010, 05:04 PM   #94 (permalink)
skysailor
Nerys: Any chance of you posting a picture or two of your fuel "washing" setup? I happened upon this discussion site while searching for information on removing the ethanol from auto fuel for using in my homebuilt experimental category aircraft. Reason is my aircraft has fiberglass fuel tanks and the engine (2-stroke Rotax) is not rated to use fuel with more than 5% ethanol and recommended to use E0 only. You seem to have had good luck with your setup and I would like to duplicate it. Have you ever tested your final, twice-washed, fuel for ethanol content using the qwik test system? Your research is very much appreciated.
