Old 04-23-2010, 02:42 PM   #4 (permalink)
Ryland
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
Originally Posted by vpoppv View Post
I'm thinking a hub motor would be advantageous for a hybrid.
but why? you could shorten the drive shaft and have the motor right off the tranny.
As for CV shafts being another moving part, that is true, but as an example Honda civic drive shafts tend to last 200,000 miles and I would think that the reduction in unsprung weight would increase the efficentecy enough to make it worth while, the slightly larger heavier motor should be cheaper to build as well and that should offset the cost of a cv joint or two.
