Originally Posted by Christ
I thought this to myself, but didn't mention it, because "Frank-Lee", if you're not willing to take the carb apart to put a few gaskets in it, you're probably not going to be interested in re-jetting it, either.
Me, on the other hand, I'd be the one trying to make my own jets on a lathe.
You don't have to take the carb apart to lean it out under high manifold vacuum conditions.You can just run an adjustable manifold vacuum source to the float bowl vent and regulate the amount of atmospheric pressure in the bowl with the amount of vacuum you administer.
