Not sure if your gas has ethanol in it or not, but if it does it will do exactly what you are talking about, you can always try premium and see what kind of change it makes, it might cost you $.60 more to fill up but it seems like it might be worth a try.
You should also make sure that the warm air intake is fully intact and working for that will make it run poorly as well.
