28 MPG??!???!? You've got to be KIDDING me!!!
I recently embarked on a 300 mile trip in the Maxima. I generally have to fight road rage and so hypermiling comes hard for me when my pride is wounded. That and the acceleration of the Maxima is amazing compared to my minvan.
However, I managed to go all the way to Little Rock without speeding much. (you have to remember, going 10 over is an Arkansas tradition. I pass police going 10 over constantly) I also used a modified P&G when I could; ie, I left the engine running, but when I could mantain speed going down slight hills while in neutral, i took advantage of it. I also did a touch of it when I could on the interstate.
Sadly I mashed the go pedal a bit more on the trip back than I should have, but still managed a solid 28 mpg. This may not seem much, but i have a goal of breaching 30 mpg, and I haven't even done anything to reduce drag on this beast. All I've done is put 50 psi in the tires.
I do desperatly want a fuel injector cut off switch for EOC (engine off coasting?) and while I know I can keep the engine rolling while in drive (I have an automatic) I'm not versed enough in the rules of auto trannys, so I fear damaging the thing. I think keeping it in drive at speed and cutting off the fuel shouldn't pose any problems, especially if my TC stays locked in . But if the engine stops spinning while in gear, what then? I could put it in neutral and kill the engine, but then that'll stress the aging starter.
Either way, getting that figure got me going. It's proven to me it can be done, and that getting a SGII might actually be worth it!
 RIP Maxima 1997-2012
Originally Posted by jamesqf
I think you missed the point I was trying to make, which is that it's not rational to do either speed or fuel economy mods for economic reasons. You do it as a form of recreation, for the fun and for the challenge.
