Old 04-26-2010, 01:08 PM   #4 (permalink)
PaleMelanesian
Hypermiler
PaleMelanesian's Avatar
90 day: 69.2 mpg (US)
PaleFit - '09 Honda Fit Sport
Wagons
90 day: 44.06 mpg (US)
Having replaced a set of Michelins (symmetry, decent LRR tires themselves) with a new set of Fuel Max tires, I'll say the following:
The Fuel Max are quieter and a smoother ride.
The Fuel Max at 44 psi were much softer-feeling than the Michelins. Going up to 51 psi brought back the solid feel I was expecting.
I've seen about 1 mpg improvement (23 vs 22) in the Odyssey.
You're getting 46 mpg. Just for comparison, let's say the FuelMax will match that and the Michelins will get 48 mpg. Over a 60,000 mile lifetime, that's worth about 54 gallons, or $150 at 2.75/gallon. 4 of the Michelins will cost $128 more than the FuelMax's, so you'd actually be ahead from the fuel savings.
If you count only a 1 mpg increase, it's $75 savings, or a slight loss overall. Still, I'd probably go with the Michelins.
I'd rather spend money on tires than on fuel, considering the nationalities of the two sources.
The Following User Says Thank You to PaleMelanesian For This Useful Post:
silverinsight2 (04-26-2010)
