Old 04-26-2010, 01:39 PM   #67 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
Originally Posted by suspectnumber961 View Post
It's just that it made me nervous at higher speeds in corners...and I also put some fancy retreads on the back that had a curved tread surface so you didn't see the loss of traction when the tires of the day folded over and ran on the edge. Problem was they probably set the rear a little too high.
For whatever reason...that's mostly all I drove for 5-8 years or so...british roadsters...from the Spitfire to a 56 Jag...with some TRs in between. Those were the good old days...freezing my *ss off...noisy rattling excuses for side windows...steering wheels that left no room for your legs....fortunately...didn't get to meet any trees though.
Ah, well, we're probably also talking about different time periods, then... i.e. different parts, different tires, different... well, everything!
I can guarantee you I wasn't using retreaded bias-ply tires that "folded over" while cornering. I wasn't using any sort of "stock" suspension equipment, only aftermarket stuff designed to fit in the stock locations.
That's me, though, to not think about things like that. Really, were we even operating the same car?
