exhaust system mods, straight through?
Can I call on the collective wisdom for help. What difference does it make to throw away the makers exhaust system and fit a larger bore burgess type straight thru silencer. the initial pipe dia out of the turbo is 2,3/4in then it finally comes down to 1,3/4 at the tail pipe.
This would be into to my 97 , mazda RF turbo diesel intercooled vitara?
Theres no point in doing this if the difference is likely to be minmal.
