Originally Posted by aerohead
Weight's not an issue when the engineers synchronize the traffic lights and abolish the left turn which makes synchronization impossible.
If you can't turn left, then won't you have to drive a block past your intended street, make a right, go down a block, make a right, go down a block, and make another right? This will take you back to your intended turn (had you been allowed to turn left), but you have now driven 4 extra blocks and made 3 extra turns, some of which you may have had to slow down or stop for. Also, you might have to stop and wait now at the original intersection if you happen to hit the light wrong. Is there some study that shows this is more efficient than allowing left turns? Seems like a lot of extra mileage, and I'm not sure people will put up with it.
