Old 04-29-2010, 03:27 AM   #1 (permalink)
Gasoline Fumes
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
Honda Alternator with ELD
The 1991 Honda Civic Wagon I'm currently driving has an Electric Load Detector in the charging system.
Description here:
I monitored the voltage while driving and it works exactly as described 19 years later.
But I don't understand why it goes to full voltage above 65 km/h (40 MPH). I'm usually cruising at 50-60 MPH. Should I be thinking about tricking the alternator? I'm not yet sure what kind of signal the ECU is sending. Or should I be thinking about cutting the VSS signal in half? Any reason for the ECU to know the actual speed? The VSS is in the speedometer, driven by a cable, so no issues with displayed speed on the gauge.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
The Following User Says Thank You to Gasoline Fumes For This Useful Post:
Piwoslaw (04-29-2010)
