I found mine by jacking my car's driver's side front tire up off the ground (with parking brake on!), and searching through all the pins connected to my ECU (computer) while rotating the driver's side tire. Sure enough, it was the last one i could have checked, and it was also green and yellow (I don't remember if it was G/Y or Y/G...) I don't drive a sube, but the technique may work for you anyhow.
