Looks like a good start. Do you think it would create too much turbulence if you lower the front top edge enough to allow those behind you to see your third break light? Or will it be visible through the plastic? Or could it be relocated to the top center of the tailgate?
I've seen so many cases where one break light has burnt out and when the driver pumps the brakes it looks like a turn signal. I really appreciate the third light.
