Old 04-30-2010, 02:32 PM   #7 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
Thought of something else, if you only plan on lightweight stuff...
Get yourself some metal conduit (or PVC tubing) and add a couple support struts from side to side across the bottom, then stretch cargo netting over them and secure it to the sides as well. You can close in the rear as much as you need with a piece of coroplast bent along the fluting.
