Old 05-01-2010, 06:42 PM   #1 (permalink)
Verdann
Verdann's Avatar
Little Red wagon - '94 Geo Metro GE
90 day: 43.71 mpg (US)
Ruber Draco - '02 Kia Rio Sedan
90 day: 25.53 mpg (US)
Compression Test results questions.
So I knew I had a dead cylinder from a previous dry test that I did. Today I finally got around to doing dry/wet tests to check if it was rings or valves. Looks like valves from what I understand, but I wanted to post and get a second opinion on my results.
Dry Wet
Cyl 1 170psi 215psi
Cyl 2 150psi 185psi
Cyl 3 0psi 0psi
With those results all I need is valves right? the psi should always go up with a wet test? or am I looking at needing a to do rings as well? If it's rings, then I'm gonna have to wait a while longer, cause I can afford to do valves, but not rings at the moment.
