Old 05-01-2010, 10:33 PM   #98 (permalink)
Allch Chcar
EtOH
Allch Chcar's Avatar
Cordelia - '15 Mazda Mazda3 i Sport
90 day: 37.83 mpg (US)
Nerys,
Diesel only has 10% more energy per gallon than Gasoline. Read the LHV for Gasoline/Diesel.
Higher compression increases the power by increasing the thermodynamic efficiency. Usually it's mixed with a high revving sports cars because high rpm cams bleed off compression which means they don't make very much torque at low RPM. A good example of high compression in an economy car is the First Gen Honda Civic Hybrid, 88ft-lbs of torque at 2800RPM from a 1.3Liter and 10.8:1 Static Compression on regular grade gasoline. Peak efficiency for a spark ignition engine is around 17:1 and cannot be done on Gasoline with a spark plug. Diesel engines run leaner than Gasoline and use compressed ignition but they usually need a turbo to keep generating power past 3k RPM.
It looks like washing Gasoline is working for you. The change in MPG is ridiculously higher, 16% more MPG?
-Allch Chcar
The Following User Says Thank You to Allch Chcar For This Useful Post:
ShadeTreeMech (05-02-2010)
