Old 05-02-2010, 08:01 PM   #113 (permalink)
gone-ot
...beats walking...
...divide the total weight of your vehicle by four, that's the rated load the tires you're using should be rated at, or slightly above.
...since rated load does increase with air pressure, you can tweek things up to the "max" sidewall airpressure.
...I'm assuming this increase in load rating is linear, but it's probably not actually linear.
