Old 05-03-2010, 06:44 AM   #4 (permalink)
fatman57
Originally Posted by kidashley25 View Post
does it cause higher voltage?
in laymans terms it should create higher voltage at a much lower current but as explained above there are reasons it shouldn't/wouldn't work......
electric motors running on higher voltage is MUCH better than a lower voltage with higher amps...............the brief idea here being use only a few batteries (say 4 which is what you will get into most cars) then convert to a higher voltage to run your motor.
