Originally Posted by CapriRacer
Crown Victoria Police Special: P225/60R16 97V 35 psi front and rear
Bottomline: Sgt. Storton did not present correct information at the time he published his article. And he could have prevented that mistake by simply visiting a Ford dealer.
What are you going on about? because he says 35 psi instead of making a chart you dismiss the whole of the article?
re: grip, look at your own pic
you can clearly see the contact patch getting more rectangular with higher psi. Meaning the load is pretty well balanced across the tread, not round cross sectioned.
Look, guy posted his test results, where are yours?
