Originally Posted by Christ
Nope, because it won't work. The fuel used to keep your engine cool is primarily designed to keep it from knocking, which can't be helped by external cooling. You can help it with water injection, though.
Seriously? So we are all burning more fuel than necessary for engine operations? Would a proper H20 injection setup let you trim some fuel flow?
