Old 05-05-2010, 09:39 AM   #35 (permalink)
PaleMelanesian
Hypermiler
PaleMelanesian's Avatar
90 day: 69.2 mpg (US)
PaleFit - '09 Honda Fit Sport
Wagons
90 day: 44.06 mpg (US)
Originally Posted by tjts1 View Post
Give the same type of driving and modifications you have, it will beat your mileage.
Originally Posted by SentraSE-R View Post
I take it you've never driven a manual transmission automobile, because you're surely not speaking from experience.
I'm with Sentra on this one. My car is stock except for a grille block. That leaves only driving style as the factor in my mileage. An Auto will not allow me to run in the rpm/load range I need, and will not allow me to EOC and bump-start. I'd be looking at 50's mpg instead of 80+.
A computer-controlled auto can be at best be equal to a well-driven manual. On the highway, once the gears are engaged and locked, the only difference is gear ratios. Around town, there's the whole rpm/load issue, torque converter slippage, poorly chosen shift points, etc working against an automatic.
